dnes som pomocou aplikacie torque pro zistil nasledovné,
farebne označené chyby
Mode $06 report generated by Torque for Android
Test report:
MID:$01 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 1 Sensor 1
Max: 0,50032V Min: 0,50032V
Test result value: 0,50032V
PASS
MID:$01 TID:$02
Lean to Rich sensor threshold voltage(constant) - O2 Bank 1 Sensor 1
PASS
MID:$01 TID:$03
Low sensor Voltage for switch time calculation - O2 Bank 1 Sensor 1
Max: 0,40016V Min: 0,40016V
Test result value: 0,40016V
PASS
MID:$01 TID:$04
High sensor Voltage for switch time calculation - O2 Bank 1 Sensor 1
Max: 0,60036V Min: 0,60036V
Test result value: 0,60036V
PASS
MID:$01 TID:$05
Rich to Lean sensor switch time(calculated) - O2 Bank 1 Sensor 1
Max: 199ms Min: 0ms
Test result value: 32ms
PASS
MID:$01 TID:$06
Lean to Rich sensor switch time(calculated) - O2 Bank 1 Sensor 1
Max: 199ms Min: 0ms
Test result value: 20ms
PASS
MID:$01 TID:$80
Max: 65 535Changes Min: 25Changes
Test result value: 102Changes
PASS
MID:$01 TID:$81
Test result value: 107Changes
PASS
MID:$02 TID:$8b
- O2 Bank 1 Sensor 2
Max: 7,99527V Min: 0,77531V
Test result value: 0,92574V
PASS
MID:$02 TID:$8c
Max: 0,10004V Min: 0V
Test result value: 0,0937V
PASS
MID:$21 TID:$a0
- Catalyst Monitor Bank 1
Max: 3,99977 Min: 0,15982
Test result value: 0,99887
PASS
MID:$01 TID:$01
PASS
MID:$01 TID:$02
PASS
MID:$01 TID:$03
PASS
MID:$01 TID:$04
PASS
MID:$01 TID:$05
Max: 199ms Min: 0ms
PASS
MID:$01 TID:$06
Max: 199ms Min: 0ms
PASS
MID:$01 TID:$80
PASS
MID:$01 TID:$81
PASS
MID:$02 TID:$8b
PASS
MID:$02 TID:$8c
PASS
MID:$21 TID:$a0
PASS
MID:$35 TID:$b0
Max: 100Count Min: 0Count
Test result value: 0Count
PASS
MID:$35 TID:$b1
PASS
MID:$41 TID:$8d
- O2 Heater Monitor Bank 1 - Sensor 1
Max: 41 008 Min: 10 432
Test result value: 65 520
FAIL
MID:$41 TID:$d2
Max: 8Count Min: 0Count
PASS
MID:$41 TID:$d3
Max: 2,001 Min: -2
Test result value: 0,647
PASS
MID:$42 TID:$d2
- O2 Heater Monitor Bank 1 - Sensor 2
PASS
MID:$42 TID:$d3
Max: 2,001 Min: -2
Test result value: 0,612
PASS
MID:$91 TID:$33
Max: 2 Min: 4 177
Test result value: 13 200
FAIL
MID:$a2 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data
Max: 65 535Count Min: 0Count
PASS
MID:$a2 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data
PASS
MID:$a3 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data
PASS
MID:$a3 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data
PASS
MID:$a4 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data
PASS
MID:$a4 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data
PASS
MID:$a5 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data
PASS
MID:$a5 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data
PASS
vie mi niekto vysvetliť čo znamenajú tieto chyby ???
